Question about on CR and turbocharging
I am going to have to do the heads on the car because the valve seals are shot, it's burning oil. I was going to do just springs, but if the valveguides are gone, I am wasting time. I also have a Turbotech 60-1 kit, complete finally, ready to install.
I am not looking to run a lot of boost, not at all. I am not looking to make crazy dyno numbers. I am looking to see what my options are.
First question, what is the dishing of stock LS1 pistons, if any? That will help determine the compression ratio.
Next question, what kind of boost could I do with a turbo on a motor with the to be determined CR. Say it is 10.8:1, could I do five pounds? Three? I run 93 octane all the time, considering alcohol injection. If I have to retard the timing, I can do that too.
So much to think about, please guide me...
Thanks,
George
The stock pistons have 0 dish. Good luck.
What about pistons on the 6.0L motor? Any dish, or flat tops too? I am contemplating a 6.0L iron block. Sure, it'll add some weight. But I will do what every turbo guy does.
Turn the ****...
Thank you both! Anything else?
If this is what you think, you definitely do not need a iron block. Save the weight!
Even Lengerfelter uses aluminum blocks, they'll be fine unless you have ludicrous horsepower.
I am thinking that the valve seals are the cause of the blue smoke. How bad can the stock shortblock be? Could I get away with just a H&C swapout for now?
And thank you for reminding me that I am budget building.
Seriously, no joke, I forgot. I got ahead of myself. Again.
O.K i need to get this straight. What motor are you running in your car? If it's the LQ4 motor, then with the stock short block and 6.0 heads you'll be around 9.4:1 compression. Because the lq4 has a small dished piston. If it's the LQ9 6.0 it's 10:1 compression becase the lq9 uses a flat top piston. Also if your getting blue smoke make sure to do a cylinder leakdown test and compression test to make sure your rings aren't shot.
It's a stock motor 2000 Camaro. I am pretty sure it's the valve seals, the valvetrain has always been a bit noisy on this car. But I will do the check. What should the compression read?
