how much boost are you pushing your stock bottom end iron block?
ALUMINUM will get you well into the 9s
my gto was only at 12psi and went 10.7 with a 1.8 60ft
we turned it up to 22psi for ***** and giggles and damn.
never went back to the track on the 22psi but mph on our local (hwy track) the car was trapping 142ish babying it out of the hole,
stock production block with studs
Stock bottem end '05 5.3 here. Been throwing 6, 9 and now 14lbs boost on it, seems like it is still laughing at me. Zero knock, 12.5-13 deg timing full boost, 10.8-11.0 AFR, 82% duty cycle on 60lb injectors.
Trust me when I say this, boost is very addictive. What a rush
#34
Well the fuel system will be purchased with the f1 thru brute speed. He gives a damn good discount on packages. (Twin walbro with 80lbs injectors are like $215 extra or something like that)
My 6.0 will be n/a probably until the 2014 holley ls fest
#35
LS1Tech Sponsor
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
Thanks, I appreciate it! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
#36
160k stock 5.3l/ 317 heads 76mm right now 14 psi @ 21deg. timing and shitty converter in 240sx chassis. I took my co-worker for a spin his response, Dam YO when you hear that whistle that bitch is GONEEEE!! lmaoo have about 1k miles of HARDDD driving. still strong.
#40
i made 630 on a mustang dyno through a 80e , with a bone stock 6.0 shortblock and 13 psi from a 71 mm.
but if you want 9's ..... go aluminum. weight is key when searching for e.t.
