TT + 390ci..........which turbos....Modular Turbo CBR F2....
You can't run stock gauges with the Holley, remember that. I don't know if they got the coil issue fixed either. I personally would run BS3 and an AMS 1000 with C02 on something of this caliber.
#35
Ditto.
possibly think about 200lber's if you ever want E85, do it once, the prices are pretty close. I would do a -8 return however, again, you have to buy line anyway, and its better to have a large return for free flowing excess fuel.
the 411 will be fine for your goals.
#36
i would do some fic2000 and with a aeromotive 13110 regualator with some walbros intank. with atleast a 8an return.
i have two aeromotive a1000 fuel pumps, a 13110 regulator, and some fic2000 injectors. and a 10an feed and a 10 an return
pretty much i have is a 2000hp kit from aeromotive they sell
#37
13110 fpr. Forgot the pn#. -8an return is what it has also. Aeromotive has a -10an inline fuel filter. 120lb/1200cc injectors will support 1000rwhp on e85. No need for -10an return. -8 return will support 1500. I'd keep the fuel pumps internal. Just run the second one off a vacuum actuated hobbs switch.
#38
I went with the red belt drive fuel pump and the 13113 reg. Got told that any electric pump is going to cook the fuel if you plan on driving for over 2 to 3 hours. FIC2150's. Better to overkill the system as others have said.
#39
Ditto.
