Who Is Running a GT91?
Old Dec 23, 2012 | 05:45 PM
XpEdItIoUs's Avatar
Default Who Is Running a GT91?
I currently have the T4 GT91 with the 94mm turbine wheel, Anyone ever take BP readings with one? What is your setup and pressure ratio?
I have a 370 and going with PRC 260cc ls3 heads, But I'm thinking about upgrading to the 97mm turbine wheel and going to a T6 flange. This car is going to be a light (2,900 lbs) street/strip car with a stalled auto. I don't want to spend the extra money if it's not necessary, I'm looking to be at around 1.5:1 at 20 psi of intake pressure.
Old Dec 23, 2012 | 07:51 PM
XpEdItIoUs's Avatar
No one has logged any readings on this? I'm sending the turbo in for a rebuild next week and don't want to do this twice.
Old Dec 23, 2012 | 08:01 PM
Cam72aro's Avatar
I have a t6 gt91 on a 408. No bp readings though as I just got it up and running.
Old Dec 23, 2012 | 08:32 PM
XpEdItIoUs's Avatar
will you be doing some anytime soon?
Old Dec 23, 2012 | 08:54 PM
Sales@Tick's Avatar
Even with the 97mm wheel you will never see 1.5:1 with that turbo. You'd need at least a 111mm wheel to achieve those readings. Jose could tell you better than me but from what I've seen on a outlaw drag radial car I did a cam for he doesn't even see those readings and his turbine wheel measures 130mm. Granted this is a 434 but it's still relevant.
Old Dec 23, 2012 | 09:26 PM
Cam72aro's Avatar
What type of gauge would i need to read bp and do I read it in the down pipe? I can get readings for you, just need to know how to do it.
Old Dec 23, 2012 | 10:16 PM
oange ss's Avatar
BP measurement has to be taken before the turbine
Old Dec 23, 2012 | 11:18 PM
XpEdItIoUs's Avatar
Would a pressure ratio of 2:1 be more likely?
Old Dec 23, 2012 | 11:34 PM
XpEdItIoUs's Avatar
I know KILLER-LS1 mentioned he was at a 2:1 pressure ratio with this turbo, I don't know exactly what the intake pressure was but I believe it was 17 psi on his 408. I also read he was dropping pressure across his intercooler. I'm just trying to make a decision as to keeping the T4 94 turbine or if switching out to a T6 97mm turbine is even worth the extra $, Now is the time since I will be sending it out to Forced Inductions.
Old Dec 23, 2012 | 11:44 PM
stock48's Avatar
9 Second Truck Club
How quick are you trying to run, and what rpm will you be turning?
Old Dec 24, 2012 | 12:00 AM
Sales@Tick's Avatar
At high boost yes.
Any mechanical pressure gauge will work, just need to be able to watch it or a way to record it.
This.
It would be worth it in my opinion even though you wouldn't see the pressure ratio you wanted at high boost. That said, it's not necessarily a bad thing and it will still make good power. The 2.0:1 scenario is much more likely at high boost and the worse drive pressure gets the further you move past the higher efficiency islands of the compressor map at those pressure ratios. Some turbo's like high pressure ratio's some don't. Someone like Jose could tell you better about that than me though.
