Guys I need some help
Old Jan 2, 2013 | 10:26 AM
9sectruck's Avatar
I placed a pin in red 38 on the ecm and from there to the dk blue wire that goes to the gauge, (via hp tuner forum)
then the purple from the sending unit to the purple in the 02 harness,
tried both the 98 sending unit and the 02 sending unit, the only difference the 98 has a bigger sweep for voltage then the 02 does but gauge still reads full all the time per both sending unit
Old Jan 2, 2013 | 10:31 AM
98Camarod's Avatar
Is the problem not the sending unit and its the gauge reading? I thought the 98 had a wierd ohm range for the gas gauge.
Old Jan 2, 2013 | 10:47 AM
9sectruck's Avatar
it does its backwards from the rest 250 empty and 30 full 99 up are opposite.
so I would think the gauge would just read backwards.
Old Jan 2, 2013 | 01:04 PM
MUSTANGBRKR02's Avatar
I thought you had to do something in the tune to make the gauge read properly?
Old Jan 2, 2013 | 01:06 PM
98Camarod's Avatar
Segment swap comes to mind.
Old Jan 2, 2013 | 01:07 PM
9sectruck's Avatar
THE ECM DOSE HAVE THE UP DATED OS, 122526155 or somthing like that.
its the 3bar enhanced converted from what ever but I dont know if I need to change something else
Old Jan 2, 2013 | 01:13 PM
I just searched and there are a few threads about a van OS.
I'm on my phone but ill try to copy them here.
Old Jan 2, 2013 | 01:17 PM
This is the one I was reading. Not sure how that applys to a updated OS though.
https://ls1tech.com/forums/pcm-diagn...p-98-99-a.html
Old Jan 2, 2013 | 01:47 PM
9sectruck's Avatar
This is the link that I have been reading going to try this tune tonight to try to get it to work, second post 4l80 conversion
http://www.hptuners.com/forum/showth...S+GAUGE&page=3
Old Jan 23, 2013 | 11:29 PM
M2W-GTO's Avatar
Karma for karma, lol
