LQ4 alternator relocation bracket
Old Jan 7, 2013 | 02:00 AM
Jadedbird's Avatar
Default LQ4 alternator relocation bracket
So i got my 6.0 now i need an alternator Relocation bracket
Tah dah
I did some searching and I found one on spoolin for $175
And i heard the huron speed has some trouble lining up correctly,
So i was wondering what all you 6.0 guys do?
And ill need a bigger belt too right?
Old Jan 7, 2013 | 02:13 AM
denmah's Avatar
Moderator
the modular/cbr performance one is great, comes with a belt if you tell them what you are running
we just threw it on a 6.0 turbo powered 2002 ws6 with power steering
Old Jan 7, 2013 | 12:41 PM
Jadedbird's Avatar
Ill have to check in on one of those.
Any problems? Any pics?
Old Jan 21, 2013 | 10:07 PM
Jadedbird's Avatar
bump????
Old Jan 21, 2013 | 10:23 PM
Boosted Firehawk's Avatar
Im looking for one to RUN WITH NO accessories besides the crank and alternator.
If your looking for the same lmk which you find.
I know mod turbo is a good one though
Old Jan 21, 2013 | 10:26 PM
Jadedbird's Avatar
im running all accessories. ac included
looking for 9s at full weight
Old Jan 21, 2013 | 11:34 PM
1BADAZZSS's Avatar
my cbr fits nice
Old Jan 22, 2013 | 01:33 AM
jt76's Avatar
I had the spoolin' performance one. Tossed the belt twice. I ended up shimming the tensioner bracket and that fixed the problem. Going with the alt in the stock location this time around though.
Old Jan 22, 2013 | 04:19 AM
same o'j's Avatar
Tah dah
hope this will help :
http://www.cbrperformanceproducts.co...p/06072011.htm
Old Jan 22, 2013 | 09:59 AM
Jadedbird's Avatar
I might go cbr. Does it clear factory ws6 hood?
Old Jan 22, 2013 | 10:52 AM
skinnies's Avatar
What kit you doing? I say try to make it work in the factory location, it looks WAY better this way, if the kit is built right it's doable.
Old Jan 22, 2013 | 01:12 PM
Jadedbird's Avatar
An lq4 in the fbodys wont fit the alternator in the factory position right?
Old Jan 23, 2013 | 08:22 AM
ModularTurbo's Avatar
It will fit under any F-body hood.
Old Jan 23, 2013 | 09:39 AM
mrstepheneades's Avatar
im running the modular cbr one on mine..... easy install and like stated above comes with belt....
Not the best pic of it but it deletes the tensioner and replaces with a turn buckle type......
Old Jan 23, 2013 | 09:53 AM
jfisher's Avatar
I'm in a similar situation, but I want a low mount alt on the driver side for use with the truck accessories. I'll probably just go with a custom unit unless I find something that's fairly priced and what I'm looking for.
Old Jan 23, 2013 | 10:23 AM
Jadedbird's Avatar
Pics not working.
It deletes the tensioner?
Old Jan 23, 2013 | 10:30 AM
Pics not working.
Pic showing up on this end......
Yeah it takes you tensioner out and puts a turn buckle on the back side of alternator that acts as the tensioner.... Like you see and some custom old cars...
ill see if i cant get a better pic up
Old Jan 23, 2013 | 10:34 AM
Pics not working.
here ya go
think i paid 189.99..... comes with all you need.... May need to lengthen the connector wire that plugs in alternator put that takes 2 minutes tops
hope this helps
Old Jan 23, 2013 | 10:37 AM
Our alternator relocation kit is the best one on the market hands down.
http://vtsql.gkvbf.servertrust.com/C...it-p/cbr01.htm
Old Jan 23, 2013 | 10:41 AM
agreed......... ran it on the car for months before the turbo build even started.... no problems whatsoever
