practical downpipe limit???
Old Jan 7, 2013 | 10:36 PM
SR-71 SS's Avatar
Default practical downpipe limit???
I am just about ready to order all my parts for my opel and had a question on down pipe size.
I know the consensus on down pipes is generally the bigger the better but where is the point of diminishing returns? This is a tube chassis car so I have room to work with up to 4" maybe a tad more per side. The minimum planned as of now is dual 3", but since space is available how big should I go?
This is essentially a street car and will have exhaust running at least to the rear axle.
Pics of car here https://ls1tech.com/forums/conversio...9-opel-gt.html
Combo is
402 cube LS2 9:5 compression
TU2 cam PRC 237 heads
Twin 6266 turbos
4l80 trans 9" rear
thanks in advance
Old Jan 8, 2013 | 06:45 AM
c0ncEpT's Avatar
I have no 1st hand experience but maybe bump it to 3.5 to go out the back. If the exhaust side is a 3" v-band you would think that would because the restriction before a 3.5" pipe. Again just speculating here.
Old Jan 8, 2013 | 10:02 AM
ls1_chevelle's Avatar
Im running 3.5" all the way back and would never do it again. 750rwhp. After seeing so many successful 2.5-3" turbo to tailpipe cars making 1000rwhp...
With that said, Id run 3".
Old Jan 8, 2013 | 10:03 AM
LS1NOVA's Avatar
I think full 3.5 is best in your case.
Old Jan 8, 2013 | 01:39 PM
jridenour31's Avatar
3.5, more than enough with those turbos and you won't need to redo them if you step up to 7675's or something down the road.
Old Jan 8, 2013 | 02:04 PM
LilJohn's Avatar
125% of the turbines exducer is the minimum rule of thumb.
3 inch has supported 700 @ the wheel on certain combos.
With the length of run you are talking... id personally do 3.5.
I would also reconsider your cam choice if it hasnt been purchased yet.
Old Jan 8, 2013 | 03:25 PM
qqwqeqwrqwqtq's Avatar
We've built several single 7675 cars at 900+rwhp with a single 3in downpipe.
That being said, dual 3 inch is not going to restrict you at all. (Not ideal but we've seen 1000++rwhp with dual 2.5 systems).
If you can easily fit dual 3.5 it certainly wouldn't hurt but I don't think it would pick up any power.
Looks like a great combo (including the cam!) in my opinion.
Old Jan 8, 2013 | 04:30 PM
That's pretty impressive. How much could you expect to pick up when going from dual 2.5" to dual 3" or 3" to 4"?
 Michael S. Palmer
Old Jan 8, 2013 | 06:48 PM
SR-71 SS's Avatar
looks like 3.5 duals it is. I prefer to overbuild now and not have to redo later should I add more cubes or more turbo down the road. I appreciate the input from everyone who posted. I will update the build thread once parts arrive and fabrication begins. Since the knickname for the opel gt is the mini vette I think it would be kind of neat if I could run the downpipes as sidepipe exhaust like the old stringrays did.
Old Jan 8, 2013 | 08:33 PM
LilJohn's Avatar
That would sound pretty wicked... i like it.
