P1SC procharged 5.3 which cam?
Thanks LS1Tech!!
Specs are 226/234 .59x/.61x 115+3. It should run very well and make great power. I normally cam 5.3's very similarly to a 5.7 as they both utilize 3.622" strokes and 6.098" rods which means they spend the exact same amount of dwell time at TDC and BDC.
Also our Stage 1 Street Heat cam which is 221/226 .609"/.605" 115+2 might work better in your heavier truck and still be great with a Procharger. Anything bigger than those two is going to make that truck a dog down low.
Agree 100%.
Did you ever get dyno numbers from the above corvette?
