Single Turbo Merge at Flange
Old Jan 14, 2013 | 09:33 PM
zraffz's Avatar
Default Single Turbo Merge at Flange
I figured I'd get an answer here as opposed to probably not getting one in the SBC section. Anyway this is technically a SBC 383 (single plane fuel injected), TFS 195cc heads and a Turbonetics TC78 Hurricane Benita 1.15 AR.
My headers are 3" collectors to 2.5" reducers, my entire hot side it 2.5" pipes but where they merge at the t4 flange (which I will call the merge at the y pipe), should I step it up to a 3" pipe at the T4 flange?
So basically two 2.5" pipes merge into a 3" y pipe at the T4 flange or should I keep it a 2.5" pipe?
Old Jan 15, 2013 | 08:58 AM
MaxxMitchell's Avatar
I do a 3" pipe usually going into a T4 flange and also place the wastegate somewhere on that 3" pipe.
Old Jan 15, 2013 | 01:03 PM
LS1NOVA's Avatar
I split the pipes like this on most builds.
Old Jan 15, 2013 | 01:18 PM
123quattro's Avatar
I made this out of 2.5" 90s. Slice the back edge off, flatten the sides in a vise, true up the edge with a disk/belt sander. Took maybe 2 hours.
Old Jan 15, 2013 | 03:04 PM
80gus's Avatar
Mate that looks so neat.
