Thinking of going turbo.....Need some Input
Was it a truck manifold kit, down pipe size, engine size, trans, rearend?
Did you ever take that setup to the strip, if so what times
If you don't mind sharing that info , you can pm me you want either way is fine
I've been playing around with some big single turbo stuff lately that always has inherent backpressure issues(I'm talking 427+ cubic inches with a single turbo) and the same issues arise in set-ups like this. There are ways to work around the backpressure issues with overlap and valve events and I've found a few tweaks can be done here and there to allow the engine to breathe up top even with the backpressure issues. Backpressure is drive pressure and drive pressure is what spools the turbo.
Now, would a T6 turbo with a 96mm+ wheel big fancy fabricated DP, stood up radiator etc. make everything peachy, yes it would....but not everyone wants to do that.
As Jon said, he has a bad *** T6 kit that will work for the guys that do want to go bigger and really make some steam(I'm one of them
), but again not everyone is up to the task of doing that. If anyone in this thread has never felt what 700rwhp+ feels like, which a T4 turbo is perfectly capable of doing, they need to try it out. My old 346 LS1 ran 113mph in the 1/8th@3950lbs. with a PT7675 turbo running 16psi...no telling what kind of BP numbers it was seeing. That amount of power was PLENTY for the street and at the track. Some of us just want more.
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Slap a 7675 on it and have martin do you a camshaft with about a 52 evo on a 230 @.050 lobe and call it done.
Get some portwork done to the heads...and a good intake... and you can reach your goal on pump gas.
Funny you say that about the EVO, here is what I came up with:
226/231 .605"/.598" 115+3
That just so happens to be a shelf cam that I carry also, so no custom cam pricing!
I agree with LilJohn though, keep it stock bore, take it out to 3.80 if you HAVE to and let it ride with a set of Wiseco Pistons and K1 rods if you want to forge it.
When are you gonna quit being overly aggressive with your IVC's and stingy with your overlap?? Even though the stroke is the same... you do have less volume to fill.
Put that stick on a 113+3 or 4.... and id be a proud Obi Wan.
