2000 silverado 2500 LD (sloppy mechanics) 4000 miles later 675whp
Nice truck I can't wait! This should be a fast, easy build for you. What are you gonna use to tune the stock ecm with? Where did you get all your parts from? Are you gonna put valve springs on it? What about head studs? Thanks
How much do those circle d converters run money wise?
Was just checking out there site.....do you run there regular converters or a single or triple disc. Noticed the triple is 1100$ that's a lot more than I thought they cost.
valvesprings yes i have pac1218s, and KMJ studs.
my friend has 317 alum heads with springs already installed in em. figure ill pull the heads, do the studs and gaskets and just throw these heads on.
yeah i am gunna throw a martin cam in it, and a newer water pump in it since who knows how old this one is, so ill do the cam while i am in there, just going nuts right away.
#36
yes stock ECM with HPtuners speed density 3 bar custom OS
putting the turbos right below the motor is the plan, like a few inches down from the manifold, i should have room, if i dont ill have t put them up front somewhere.
like 750 for a th400 unlocking one and about 900 for a locking one for a 80 and then yes 1100 for a triple billet lockup nasty ****. those are the ones i buy, i buy the 1100 dollar nasty one because they are the baddest **** i have ever used haha
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
