Forged 6.0 iron block buildup
Would you leave all of that alone to have the compression ratio low and turn up ther boost.
I should be able to get the heads to flow more without milling them to raise the compression ratio. I was looking at getting the 6.0 heads with the 317 castings.
What do you guys think?
Thanks
Low comp pistons w/big CC heads, 6.0L would be the best bet, 9:1 total comp, its a nice way to go
If I had to do it over again, I would go lower than 9:1, just so pump gas could be thrown back into the factor
That .030 over bore 6.0L block is exactly what i did....... I had AP Engineering build my short block and i went with 6.0L heads and 6.0L MLS head gaskets for my procharger setup...... heres some pics of mine with coated pistons.
370ci Iron block
Diamond 4.03 -15cc dish pistons
Coated piston up close
Short block and tranny almost ready to go in.
Heres the run down on the Shortblock
9:1 Compression Forged 370ci Iron Block Built by AP Engineering
Polished & Magnafluxed Stock Crank
Diamond Forged Ceramic Coated -15cc Dish 4.03" Pistons
Diamond 4130 Chromemoly Wrist Pins
Diamond Pro Select Ring Set/ File Fit
Eagle H-Beam Connecting Rods 6.125"
L19 ARP Rod Bolts
Federal Mogul 152M Main Bearings
Clevite CB663H Connecting Rod Bearings
ARP Main Studs
Blueprinted & Fully Balanced
Pinned crank
Comp XER 230/236 .592/.602 on a 114 LSA + 4
Ported LS6 Oil pump
Jwiss timing chain and Gears
And some other stuff i might of forgot...
Kyle
I am looking for some conencting rods, pistons and rings and some bearings for the engine.
The block I have is a bare block and I will need all internals to build it up strong. I was
thinking about some billet main caps. I am going blower so I would like the dished pistons to keep my compresion ratio to about 8.5. I want forged parts that can handle up to 20 pounds of boost.
Kyle
