who makes this catch can
Old Jan 30, 2013 | 12:58 AM
baggins's Avatar
Default who makes this catch can
It has an internal baffle as well... any ideas?
Old Jan 30, 2013 | 01:05 AM
alexcoreas's Avatar
Get this catch can from MIGHTYMOUSE
Old Jan 30, 2013 | 02:05 AM
baggins's Avatar
I'm not planning on a pcv setup... just -10s coming from each valve cover
Old Jan 30, 2013 | 05:48 AM
lsx1's Avatar
Blueridge motorsports makes a can similar to that, not exactly the same
Old Jan 30, 2013 | 06:54 AM
SMOKNSS's Avatar
I didn't know Mightymouse was making catch cans. Those are pretty baller looking... and I will need a new/bigger one for the turbo set up.
Old Jan 30, 2013 | 07:24 PM
Texhotrod593's Avatar
Already used his in a turbo build! i love them and they work very well!!
Old Jan 30, 2013 | 07:26 PM
Camaro9969's Avatar
Just bought one myself from him also ill show before his can and after its going to help my oil quality out I'm sure!
Old Jan 30, 2013 | 08:14 PM
westtexasbuff's Avatar
www.racepartsolutions.com sells a similar one, but only with a single -12 AN fitting.
Old Feb 1, 2013 | 11:20 AM
DaGreightOne's Avatar
how much is the mightmouse catch can?
Old Feb 1, 2013 | 11:25 AM
LS6427's Avatar
$125 shipped (boosted version)
Old Feb 1, 2013 | 11:38 AM
LS6427's Avatar
I'm gonna use this one, just have -10 lines running to it from each valve cover, every other port will be capped off, and let the crankcase gases just push their way out to the can.
http://www.jegs.com/i/JEGS-Performan...52202/10002/-1
Like "ajrothm" has on his 23psi 408ci. No vacuum, just crankcase push. So ZERO oil going into the intake....just AIR.......keep the top end clean forever.
https://ls1tech.com/forums/17099663-post5.html
Old Feb 1, 2013 | 12:28 PM
Sarg's Avatar
Was thinking of hooking my mightmouse catch can up to an exhaust vent to pull vacuum.
Old Feb 1, 2013 | 12:38 PM
milkplus's Avatar
http://www.supraforums.com/forum/sho...se-ventilation
Old Feb 1, 2013 | 12:56 PM
nhra686's Avatar
Check this one http://www.gzmotorsports.com/BT2-breather-tank.html
