Results with SD-concepts pulley set up.
Its not a problem w/the cogs though because of the teeth situation
I can snap more pics if people would like. I will have the car in the air this weekend to slap in a Spec III so I will try to remember to get some more pics.
I see 9psi by 4500 with the wrong belt (6 rib instead of 8) and the tensioner at it's lowest recommonded setting. No doubt there stuff works.
Once I receive my pulley and belt from them I will actually tension the sucker down a bit and I am sure I will see a consistant solid 12psi by 6000rpm
Agreed. I'll have to look again about the bracket...because it looks like another bracket with that pulley up top....I would like more pics if you don't mind...thanks in advance!
when I ordered my stuff I don't think the steel piece was out yet.
Do you send them your bracket or how does it all fit on there? I'm just asking lots of questions because I want to know as much as possible before I do this. I hope you understand and that its ok.
Kyle
