How are these stock 5.3 staying together
#42
This isn't the Subaru world. You cannot compare in any way the two. Different manufacturing standards, techniques, materials etc make them completely un-comparable. The only comparable things are that they have four wheels, and are propelled by tiny explosions.
#43
LOL. please dont start a war in my thread.... I have let the pass go at this time
Im really starting to lean towards the thick oil at this point,
just thinking out loud is there a possibility that the thick oil is building up behind the bearings and actually pushing the bearing out of its cradle and forcing the bearing up into the crank????
anybody's opinion....
#44
As for the weight of the oil, I choose a 10w40. I would not personally go thicker unless your tolerances are very loose and necessitate it. I run rotella 10w40 in my junk and it seems to work well.
#45
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#46
Cast pistons, rods, cranks. Just saying the same explosions are happening in both motors and applying their force to pistons, rods, cranks and valves made of the same materials and manufacturing processes. Motors are motors!
#48
I mean, I feel it's safe to assume LS3 piston's are stronger than that of the ls1 piston's, wouldn't you agree? Thus, I also feel ls1 piston's are stronger than a Subaru's stock piston. Just my opinion, though.
#49
I can't tell if you are trolling or not. It's hard for me to believe that someone could seriously even compare a 4 cylinder boxer engine to a pushrod v8 in the sense that if you can do X on one then you should be able to do Y on another.
#51
im using 10w30 penzoil synthetic on a 5.3 with around 140k.. i had something similar in my oil when i did the first oil change (i did a cam swap when i put the motor in) and the assembly lube i used caused my oil to look all glittery. i also had some metal on the magnetic drain plug/in the filter but all is well... i've been daily driving it and i ran a 11.8 last weekend on low bottle pressure lol
#52
I have an old customer who currently has 214,000 miles on his OEM stock STI long block Subaru and is making 400 awhp. For those that no nothing about the Subarus, they have about a 20% drivetrain loss due to the all wheel drive system. Chances are he is making around 500 at the crank if not a tad more. This is on a stock block with razor thin sleeves (similar to the LS1 sleeves), stock CAST pistons, stock cast rods, stock cast crank, stock as cast heads, stock valves, stock cam, stock everything except the injectors, intercooler, turbo and fuel pump.
If that little motor is able to do it with the limitations that it has from the factory (exhaust ports are horrible and have a nasty dog leg) then I don't see why a LS based motor could not also make 100+ hp per cylinder with their design. People are proving it because they are doing it. If anything I would say the Subaru block is a worse design and is harder to make serious hp on a stock block than the LS blocks. The head design is not even close to an ideal situation.
The original topic was how are people getting these stock blocks to survive. My answer is that it is in the tune. There are a number of people breaking pistons and tearing up bearings while others are able to continue to make these things survive. I say that a good bit of that is in the tune. Look at Skinnies. He has taken his straight from the junkyard motor over 800 whp and beat the crap out of it and it was a stock short block, stock heads motor. My thought is that the tune has an awful lot to do with how well the motor survives.
