Need help with double keyed crank!
Old Feb 9, 2013 | 08:23 PM
skinumback's Avatar
Default Need help with double keyed crank!
I am needing help with how to double key my crankshaft,
It is a stock 6.0 crank and I have the double keyed ATI
Balancer and Hub. My question is, should I have machine
shop cut the factory key slot all the way to end of crank
then add a key to the other side 180 degree, or just cut
Two new keys at end of crank and leave matireal between
the factory key? Thanks
Old Feb 10, 2013 | 07:33 AM
stevieturbo's Avatar
Either or, would hardly matter really.
Cheapest/easiest is bound to be modify one key and add another. Instead of cutting a further two new ones.
