help me hook up my jgs bov and wastegate please
Hey guys. I have a jgs 56mm bov and 50mm wastegate. Need someone to explain where i need to plumb the hoses.
The wg and bov have two threaded holes on side. One toward the top and one closer to base. Can anyone give me a detail explanation off where what goes? I do not have boost controller. Just using spring in wg..
Thanks
Thanks
On bov, tap into a vaccum source from the intake behind throttle body
On wastegate, vent top port to atmosphere and you can use the same vaccum source as your bov for bottom port
I used the vaccum hose off the driver side of the intake behind the throttle body for both to work from and have had no issues
So hook top port of bov and bottom port of wg to a port somewhere behind throttle body. And thats all i gotta hook up? To be good to go.? I know the other port in wg is probably for boost controller but what is other port in bov for.?
