What turbo is this ? Borg Warner/Forced Inductions
I measured 78/110 compressor and 75/83 turbine
Divided T4 housing and a see a 110 after some other numbers on the turbine housing
on the FI sight it looks like a S400SX-78 ETT*
http://www.forcedinductions.com/productsborgwarner.htm
thanks in advance
Also how laggy on a 4.8
My TC78 makes 15psi by about 3500
A friend wants to sell it to me but wasn't sure of specs- I'm also not sure if it will physically fit with my hot-side- I know the down-pipe will need to be reworked and possibly the cold side- If I don't use it he wants me to try to sell it for him.
Impressive- I nut-swing off a few of your youtube videos- Ive posted them on my local forums.
A friend mentioned he would sell it so im just doing research.
My TC78 just went 143 on 16psi- I almost hate to abandon the little soldier and just turn up the boost on it. But it has the 68mm turbine wheel and Ive been looking to upgrade to a 75mm turbine.
Some say the BW's aren't as laggy as you would think.... I dunno
That is a good turbo but what you have is also no slouch on that 4.8. You could always upgrade to the new turbonetics 78 or the Precision CEA 7675 and those would be enough for 8 second passes without redoing your kit. The S400's are great turbos but big and heavy when trying to fit it on a kit built for a TC turbo.
