help with wg placement
Old Feb 14, 2013 | 08:47 PM
vinnysnova's Avatar
Default help with wg placement
I would like to know if you guys have ran into not controlling boost because the wg was not put in the rite place. I am running out of room and I am not sure if the 44mm gates will hold it at 5 or 10psi if they are mounted between the rear two runners on my manifolds. It is a 5.3 on E85 with twin 66's. The purple circle in the second pic is where I can mount them without much pain. Thanks for the input
Attached Thumbnails help with wg placement-wg1.jpg   help with wg placement-wg2.jpg   help with wg placement-turbos.jpg
Old Feb 14, 2013 | 10:55 PM
rotary1307cc's Avatar
id probably put them on the housing itself
Old Feb 14, 2013 | 10:57 PM
denmah's Avatar
Moderator
yep
basically the only place you have room lol
Old Feb 14, 2013 | 10:58 PM
denmah's Avatar
Moderator
or right where it says DRIVER there where the circle is.
Old Feb 15, 2013 | 08:28 AM
Twin turbo c5's Avatar
I always put mine as close as possiable to the turbo but if there's not room it should work good anywhere you put it I've had some turbo kits with the wg 3ft away from the turbo and no problems.
Old Feb 15, 2013 | 04:51 PM
vinnysnova's Avatar
what about angle to the flow? I will be about 90 deg to the manifold. I would like it to be able to hold the boost to around 5psi if I want it to. Thanks for the replies
Old Feb 15, 2013 | 10:19 PM
LS1NOVA's Avatar
Id squeeze in a pipe at the best angle you can right before the turbo flange and run the pipe to where you have room. The gate will still be effective 1ft away, just need the angle decent.
or on the housing like mentioned.
Old Feb 15, 2013 | 10:47 PM
Chris@CBR's Avatar
It will be fine @ 90*, the exhaust has to turn 90* in the gate and there's valve in the way.
Cut a hole in the header just under the turbo inlet flange and route the tube the where you need it and stick a gate on it.
If you want to hold down to 5 PSI buy a gate with a 3.5 PSI spring.
You can always turn it up.
Tail has gates with 3.5 springs.
Old Feb 15, 2013 | 11:38 PM
vinnysnova's Avatar
cool. I think I will rebuild my manifolds to move the turbos up and better flow and give me room for the wg's
