Anyone thinking about getting a ON3 turbo? SAVE YOUR MONEY AND DON'T!!!
You are crying about quality on a 300 dollar turbo?
you have to understand, you are getting what you pay for, some people have fantastic luck, some dont. Its a gamble imo. Not knocking On3 here, but you have to understand, that a 300 dollar turbo is not going to be some top notch quality. The simple fact that he does not warranty them is why i choose not to use them.
Believe me, i considered it for a long while, even spoke to them a few times. I just choose to go with something ive used before that i knew was great.
I do agree that if the oil feed/drains aren't sufficient, that no turbo will last though. Whether it be a $300 turbo or a $2000 turbo, it don't make much difference..... I would make sure the oiling system was up to spec before trashing any company...... Maybe you should have tried to contact the company before posting on here and try to get the issue resolved????
Again, you gotta know that cheap in the game of going fast isn't always going to work out...... It's a gamble that works for some and not others....
Interestingly, after working unsuccessfully with Precision for a long time to get the oil burning under control, I finally did what the vendor said and put in a .070" restrictor. Precision themselves adamantly refused to consider a restrictor, and finally wanted me to send the turbo in for "free" work. From what others have posted up, that usually would mean that they would claim I caused oil starvation and charge me about $500, when all I really needed in the end was a little restrictor to go with my properly sloped -10 drain system...
Maybe Garrett and Borg Warner are true quality..... For now I'm going to play with cheap Chinese turbos because they are cheap and the success rate seems similar to what I had before.
Yeah definitly check your oiling system. I've run into issues on turbonetics turbo's getting to much oil and blamed it on other things. Check your drain and pressure its not a big deal to get it fixed if that's what's wrong.. Its man made stuff happens. Welcome to the world of hot rodding.![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
i just ripped apart my turbo and found the seal blown, dont open your mouth before you dont read the whole story, maybe you didn't read the part were i was tearing down the turbo to find the problem. if so let me qoute it for you in big cap locked letters so you can read. and once i took it apart there were gashes and grind marks all over the place.
dont get mad at me because i'm calling them out on there low quality parts if they want a good name then i suggest they make each and every turbo to the standard and not half *** piece one together with defective parts
i'll post up pics in a few so you can keep your mouth shut and learn to speak when you have the correct information.
I'm not a big ON3 turbo fan, but it does sound like the OP jumped the gun, with the bashing.
Are the grind marks, and gashes just where the turbo has been balanced?
Which seal is "blown" they are mostly metal seals(like a piston ring) in a turbo, and I can't see how one can be blown???
Leaking maybe(from too much oil pressure), but you can't blow a metal seal, like a rubber seal.
I posted the pics for those of you that can't see I will link them, I had my car at a shop and there is nothing wrong with my feed and drain I'm using all the right fittings 4AN for the feed and 10AN for the return.
And wouldn't any of you be mad wasting money as such? I bought the turbo because I saw they were a sponsor on the Tech, but it is true I get what I paid for. I bought a 300 dollar turbo and I got a 300 dollar defective turbo
#35
Sometimes you get a bad egg in a dozen, even with "high end" turbos it's a possibility. For the price, you can replace these On3's more frequently and for cheaper than servicing a high end one. Disposable's if you will. i.e. Plastic forks vs. fine silverware. Sorry to hear that you got a bad egg. I've had mine on for over a year without issue. Best of luck.
#36
#37
it was my bad luck of the bunch but first impressions last impressions, i'll be going with a different company and perhaps a different setup as a front mount turbo
#38
If you're thinking that those machining marks on the backs of the wheels are random mistakes, I'd think that they are probably for balancing instead. As far as that seal, what is going on there?
#39
those machining marks were not present when i first initially received the turbo. I took it to a shop and had in pre-inspected in front of me to make sure it was good to go. when i tore it down i found little chunks of shrapnel behind the compressor wheel, as for the seal i have no clue, i took apart my garrett to make sure everything was "correct" and i found that seal jack knifed to the next groove. so if it was my guess that is where it went wrong at first. my **** of the luck to get the bad apple but you win some you lose some.
