How to wire spal fan with stock wiring harness?
So I got a 16" spal fan and I need to know do I just splice the wires for the stock wires and connect to the spal fan wires? Here is the fan I got
http://www.a1electric.com/Merchant2/..._Code=30102082
Mine has the molex female connector on it. But last time I just stripped, wire tied, and put some of that electric grease in there and zip tied it, and made sure it was pulling and not pushing.
I just got my Spal extreme. PM me for better pricing. I know you need to save all the dough you can dude.
The three relays work together to put the 2 factory fans in series when the low setting is active and parallel when the high speed is active. Connect the light blue wire from the stock fan harness to your fan positive and ground the fan negative to the chassis. This should activate your fan when the low speed is selected by the ecu.
