Denmah inspired 82 Fairmont Futura turbo build decide to go with a big single!!
Gonna be a another awesome Fairmont. Fairmonts are becoming more and more popular.I've had one for 6 years now and people still don't know what kinda car it is. But it works good.I thought I was the only one that liked fairmonts!
More parts showed up I need to start workin on this beast, I want to have it done before the local test, and tune.
![](http://i301.photobucket.com/albums/nn55/streetsilverado/06D92619-6535-49E3-B875-4E7C51306BB3-3982-000006053D14E990.jpg)
![](http://i301.photobucket.com/albums/nn55/streetsilverado/B34E9BB6-B572-4B80-A570-1C2CFC110E56-3982-0000060550297894.jpg)
![](http://i301.photobucket.com/albums/nn55/streetsilverado/8F745676-659F-4775-9D88-F210D02E0651-3982-0000060555B5F637.jpg)
![](http://i301.photobucket.com/albums/nn55/streetsilverado/0025F28F-B2DF-4803-8693-3FCEDFA92832-3982-00000606257CA649.jpg)
Ordered a couple air to water intercoolers 4.5" thick core 3 1/2 inlet/ outlet I'm going to weld them together and make a two in one out like parish did on his truck way back when.
![](http://i301.photobucket.com/albums/nn55/streetsilverado/5018505B-01A1-4F42-9340-D52301DF2E42-3982-0000060B116D622D.jpg)
#33
Haha yeah. Thank you for all the info, videos, and write ups you share with fellow hot rodders if it wasn't for your fairmont I would of never of thought to build one. A lot people I know don't understand, or even give me crap on why I would build a ugly 1982 fairmont. Ill just have to give them a good ol complementary "fairmont challenge" ride along, and that will change there tune. Budget sleeper builds are the best in my book.
#34
So I finally got a chance to work on the rear end a little bit. Took the 8.8 apart to install spool, But I found a chip in the corner of one of the teeth. Would it hurt to run this ring, and pinion? It's a 2.73 ratio, which might be nice for freeway cruising, but could maybe hurt it at the track. There was a few small pieces of metal on the magnet in the rear end housing that where from the chip in the ring gear. No major damage that I can see except for the chipped tooth. What's everyone think. Should I go lower gear ratio, or just run it?
![](http://i301.photobucket.com/albums/nn55/streetsilverado/8A66FC3D-9B08-4806-936F-D5038CAE44B7-3747-000006CDDA7E82CF.jpg)
![](http://i301.photobucket.com/albums/nn55/streetsilverado/E9A30BF9-03C1-47E5-925A-BC60CCAFF850-3747-000006CDE2AB8275.jpg)
#35
I'm going to be running 255/60/15 DRs they are 27" tall, and the 80e has a .750:1 ratio in O/D so 2.73s would be nice for highway cruising, but I think they also might bring my 1/4mile trap Rpm down quite a bit.
#36
Looking good. I think you'll be alright with those 273's ive had a few turbo cars with that gear and they have all worked good.i've had some 140mph trap speeds with 273's.
#37
Here is some updates on my build I have all the five lug stuff off the 94 mustang installed... I used the stock control arms with the 94 spindles, rotors, calipers and brake lines on the front, and got the spooled 8.8 all mounted..
Last weekend I tore down the 4.8 that I'm going to be using in this car to fix #7 piston that popped the ring land about a year ago in a boosted truck that I use to own. Engine looks great! No other damage done than just the chip in the too of the piston the head has a few nicks in it, but nothing to bad to worry about.
![](http://i301.photobucket.com/albums/nn55/streetsilverado/9E08C6F0-B7D1-4660-8047-A33904D60249-850-0000016C286B2710.jpg)
Got the 80e all drained and ready to install the Hd2 shift kit.
![](http://i301.photobucket.com/albums/nn55/streetsilverado/0AD4A2DA-F705-4CCD-AC8A-58BD5BD9080B-850-0000016C4B334796.jpg)
