C6 Corvette build - ProCharger F-1A / 365ci / LSA / E85 [*UPDATE* 915whp/815wtq]
#102
The stock system has a pump in each tank. The passenger pump just moves fuel over to the driver side tank, and the driver side pump feeds the rail. I tapped into the stock in tank pump on the driver side and it Y's into the -8 feed line to the rail. This runs solo under 4 psi, just like stock pretty much. Above 4psi the magnafuel 750 turns on and both the stock in tank pump and the external feed the rail. Then I have some short runs connecting the regulator return to the stock feed hard line, and to the tank return bulkhead. Should keep the fuel cooler and not need a pump controller.
factory uses a vacuum system to transfer fuel form passenger side to the driver side by using the pump
#103
Here's the driver side (left) and passenger side (right)
![](https://imageshack.us/a/img132/1397/20130101180708.jpg)
#105
#106
TT-TECH Veteran
Lots of pulls is from my car Jeff Yeah those are from Bills three camera's I had on my car. And yeah I've made 1068-1089. This weekend I was running on my base boost in which it makes 950-1000 depending on the run. Atleast thats what the dyno says after multiple pulls most were like 968,972 etc... But it shows how close in power we were!
#107
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
#110
TRC combined my footage with some extra they shot while riding in my car, enjoy:
TX2K13 - 915+whp procharged corvette vs The World (10k+whp combined) - YouTube
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
#112
Thanks! ![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Me either
This week is going soooooo slow... almost Friday!
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#116
Yup. I have the stiffest spring in the Tial too so it stays closed at part throttle and doesn't make the car sound too much like a street sweeper since the proflow is muffled by the filter it comes with. At full boost though the tial pops off.
#117
The cap/block off goes in the driver side in the fuel pump assembly so you can run an aftermarket regulator. There is a 'cap' that goes on the passeger side though, but it has holes through it to act like a bypass. This allows the base pressure to drop as low as you want on your aftermarket regulator w/o impacting the fuel transfer capability.
#118
Ok cool(thanks!), so you had to put one on both sides? My car runs a standalone ProTuner 750 so all i have is a transfer hose/pump, filters and regulator. About to do a buddies C6 and I was gonna pretty much use your build as a reference chart
![Popcorn](https://ls1tech.com/forums/images/smilies/popcorn.gif)
#119
Since I haven't had experience with that before. Where did you get your caps/plugs from? Also are you using any particular C6 Z06 pump setup from any particular year? ZR1 pump an option for an intank? or are they the same? I know when I worked for Cadillac, the XLR V's shared the same pump as a Z06... anyways, thanks for the info. ![Popcorn](https://ls1tech.com/forums/images/smilies/popcorn.gif)
#120
Here are some pics and footage from the Texas Invitational. The car has been running awesome... one case of driver error on a missed shift, but besides that one pass she ran consistant mid 150mph passes all weekend. My best mph was 157mph.
Day 1 grudge matches and qualifying:
(hp number is off on Nine Ball's viper, thought that was his no nitrous number, but it was more like 900)
Day 2 KOTS and 6-speed challenge:
Lining up on the grid before heading down to the staging lane
![](https://sphotos-a.xx.fbcdn.net/hphotos-frc1/902003_162641807228882_568322651_o.jpg)
Awesome shot from day 2 qualifying racing the EVOMS GTXXXX 996 (forgot to turn on go pros this run)
![](https://sphotos-a.xx.fbcdn.net/hphotos-frc1/906459_162693687223694_1202760099_o.jpg)
cooling down before the next run
![](https://sphotos-a.xx.fbcdn.net/hphotos-prn1/p480x480/529445_365059643597896_967408830_n.jpg)
my race against the s/c viper
![](https://sphotos-b.xx.fbcdn.net/hphotos-prn1/p480x480/544859_10101298821548169_1265562513_n.jpg)
