Huron Speed A/C Turbo Kit GROUP PURCHASE!
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Jon
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic36191_1.gif)
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
__________________
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
__________________
Jon, my ? to you is obviously both kits are very similar. While using your alternator relocation bracket Does it need only the stock crank pulley and water pump? Is the tensioner and other accessories out of the picture? Im having a hard setup here and if needed I will just buy the alt. kit from you and bypass my other project.
Will the stock radiator hoses work with this turbo setup and stock water pump with your alt. rel. bracket?
cmon guys buy this kit. Jon is a real bad *** when it comes to these kits and they are top notch. He is also very easy to speak to and will always get back to you 100%
customer service is 110%
__________________
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Thanks! Appreciate it!
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
__________________
Back up, get in now to take advantage of the included extras for spots 1-5
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
__________________
Turbonetics 7675 or 7875
Comp 7679 or 7879
Precision 7675
Kit was built for a standard frame T4 with a 3" V-banded Exit.
All current T6 kits are built per order in house so we can build it however you like for your goals. We can do a T6 to retain A/C no problem!
__________________
#33
Bump!!!!
__________________
#36
Jon
__________________
#38
__________________
#39
Back up!!!!
__________________
#40
__________________
