9.0h at 150 tc78
Old Feb 28, 2013 | 11:40 AM
MLP00Z28's Avatar
Badass!! Im currently working on my turbo setup, hope I can achieve those times
Old Nov 23, 2013 | 12:39 PM
6.0mustang's Avatar
Ok, for anyone who cares, the tc78 maxed out 151mph...
I have since changed setups, s480 w/ race cover, dart 225cc heads, same cam, the car has gone 5.6@129, 9.01 @128 it doesn't have a chute so I have been lifting just past the 8th.
Old Nov 23, 2013 | 01:13 PM
87silverbullet's Avatar
Its definitely in the 8's now! Thanks for sharing the info.
Old Nov 24, 2013 | 09:46 AM
2002camaroSS's Avatar
Can't wait to see you make some full passes! How many pounds of boost?
Old Nov 24, 2013 | 10:03 AM
SPRAYED 01's Avatar
Was this the 68mm turbine tc?
Old Nov 24, 2013 | 12:19 PM
6.0mustang's Avatar
It did its best pass on 21psi i turned it up to 31psi and lifted the heads, it will be back out soon.
Old Nov 24, 2013 | 12:20 PM
6.0mustang's Avatar
Yes, this was not a 75mm
Old Nov 24, 2013 | 12:37 PM
yenkomike's Avatar
gives me hope my lq4 tc-78 nova will run 10 flat. turbine is small but still makes power.
Old Jan 2, 2016 | 04:34 AM
6.0mustang's Avatar
Been down for 2 years **** got carried away x275 88, 400" waiting for race season
Old Jan 2, 2016 | 02:47 PM
coltboostin's Avatar
. that was on 25 degrees of timing.e85
You should have some "down with baby soft" sticker made.
Good work!
Old Jan 3, 2016 | 12:04 AM
tonypaul's Avatar
th400. 3.31 gears, 28x10.50. when you were th400/3.31 on a 28" what was your rpm's looking like @ the stripe(1/4mile)?
Old Jan 22, 2016 | 12:53 AM
  #32
NemeSS's Avatar
Do u have the 1.15 t78 for sale by chance?
Old Jan 22, 2016 | 01:09 PM
  #33
stoverz28's Avatar
So it was a 1.15 ar?
I have the same turbo but with a .96 ar on a 5.3. Power falls off right around 6k at 15psi/680rw. Where did yours begin to nose over?
I thought I almost had it maxed out the way power falls off up top but now you have me thinking otherwise.
Old Jan 22, 2016 | 11:29 PM
  #34
NemeSS's Avatar
Ive been looking foe. 1.15 at tc78 for a while now. Hard to come by nowadays.
Old Jan 23, 2016 | 08:37 AM
  #35
sbcgenII's Avatar
I think comp turbo can get you a 1.15 housing.
By Brett Foote | 2026-06-04 05:00:17
