91 camaro 6.0 LS3 heads turbo build
This is my high school car Ive had it since 98 it was originally a 305 auto then it went to a lt1 with a 6 speed in 2002 then in 04 a 383 LT4 that made 550 to the wheels then I sold that motor and bought a house and for the past 4 years the car sat in the corner of the garage and got abused
well time to bring her back to life
Ive got a
L76 Vortec max 6.0 even though they are LS3 heads im pulling them and puting some off the shelf LS3 heads (as cast they are 70 cc so it will drop the compression some) and I have them sitting around from another motor I built
Ill be replacing the valley pump lifters to delete all the crap that it had DOD AFM VVT
Im going to use a LS9 cam
I have a KY turbo kit with a t78 turbo (68mm) 96 AR
kmj head studs
holley dominator fuel pump sumped tank -8 lines to the motor
holley high ram intake with 102 mm TB
Holley 83 injectors
Holley dominator ecu with boost control meth and trans
built 4l80e still need convertor im thinking around a 3400 stall
Ill regap the rings for now
My goals are to make around 700 and get into the 9s Ill build a 9 inch and it will have a cage too
hear are some pics for the visual guys that didnt read a word I just typed
Ive got a
kmj head studs
Holley 83 injectors
