Looking For the BEST BLOW DRYER for 800-1000hp.
Pertaining to a turbo only. What is the best option out there for a good price that can support between 800 and 1000 hp. and spool up around 3 grandish.
going on a 9.5.1 static comp.6.0 with built heads (manual) car
Im not savy with turbos. Please enlighten me.
PT88 ---gt45-88/ gt50-88/ s480-88/GT91.....and you could probably do 800 with a 78 honestly. Ill let the turbo gurus tell you though, but based on what I have seen that is the norm. and those turbos leave a little more room to grow sometimes.
it may be on the lower end of your goal, but with the manual transmission i would suggest a comp 7879, or a turbonetics 7875. both of those turbos will make big power, would spool quickly with the larger cubes, and will also fit nicely in an fbody engine bay (assuming thats what you are using)
a 3.5" down pipe would work well too.
hope this helps! if you are interested in purchasing a turbo shoot me a p.m! you'll like our prices.
-Casey
-Casey
__________________
YOUR SOURCE FOR ALL THINGS TURBO!
CASEY@HURONSPEED.COM
Check us out on Facebook at: www.facebook.com/HuronSpeed
TWITTER @HURONSPEED
TWITTER @HURONSPEED
