Turbo Mounted to Frame from Comp Housing?
Old Mar 4, 2013 | 07:52 PM
Ping King's Avatar
Default Turbo Mounted to Frame from Comp Housing?
Hi Everyone. I see that a lot of people mount their turbos to the frame using the turbine side of the turbo or the hotside piping. Has anyone used the compressor housing bolts to fashion a hard mount bracket? I don't feel comfortable doing this since all of the weight will be hanging on the aluminum housing.
Any comments?
Old Mar 4, 2013 | 09:20 PM
runsfromdacops's Avatar
both of my turbos are mounted in this way. i had some brackets cut to use 3 of the 6 bolts to mount the turbos
Old Mar 5, 2013 | 02:40 AM
itsslow98's Avatar
Mine has a small bracket on the compressor that bolts to the front of the motor. You gotta figure the crossover holds some of the weight as well.
