Forced inductions.. Oil Coolers???
Old Mar 6, 2013 | 08:22 PM
1972nova's Avatar
Default Forced inductions.. Oil Coolers???
Ok I have been thinking about adding an oil cooler to my nova. No, I have not monitored oil temps. My pressure always stays around 50 and my water temps are always around 190 even on hot days. I run a short filled to lower waterpump holes lq9 truck block .030 over.
I am switching to 15w40 rotella t this year..
Not sure if the cooler is needed or if anyone else runs one..it would be some more weight and some more hose to route. IF I do one it will be -12 hose.
Old Mar 6, 2013 | 08:39 PM
98Z28CobraKiller's Avatar
Restricted User
I think I'm going to start monitoring mine also. Having seen oil temps on a street driven turbo car without a cooler, I decided that perhaps I didn't want to know mine. I know, its the equivalent of covering your ears and yelling "I can't hear you!"
Old Mar 7, 2013 | 05:42 AM
Sarg's Avatar
It can't hurt, just make sure it has a thermostatic bypass on it.
Old Mar 7, 2013 | 12:11 PM
PontiacPOWA's Avatar
How hot is "too hot" for oil temps?
Old Mar 7, 2013 | 01:34 PM
rotary1307cc's Avatar
Keep the coolant temps in check and the oil will mirror it. If it is just a street/strip car you will never have a problem. Tracking it would be a different story
Mine is always in the area of 190-210
Old Mar 7, 2013 | 07:09 PM
1972nova's Avatar
Well I guess Ill toss a gauge in there first to see what I can see. I dont have issues and the oil gets changed A TON. I use K&N filters and good oil, but my concern would be the whole turbo thing with the block being short filled. Obviously with a short fill not coolant is in the bottom of the block to cool the engine and the coolant may stay around 190* in the head where the temp sensor is but who concerned about oil temps. Im sure they are high even without monitoring them.
Old Mar 7, 2013 | 08:29 PM
Sarg's Avatar
My wife's stock CTS-V gets as high as 235 and apparently this is not out of the ordinary for a stock CTS-V as it has been reported by numerous others.
Old Mar 7, 2013 | 09:53 PM
yeah didnt see that block fill part, definitely will see higher oil temps
