fuel pressure problems.
Old Mar 12, 2013 | 02:05 PM
  #61
stevieturbo's Avatar
Clearly the FPR is doing what it's supposed to do. The 42/50 proves that.
Draw a schematic, detailing exactly how you have it configured and the size of any lines. Any descriptions so far are very vague.
But your first setup should have worked. You proved the system is capable of making pressure, ie 100psi. So the only issue can be a lack of fuel flow.
And as I said, that feed line into the reg looks bloody small. it may have a -6 threaded fitting on it, but what size is the actual hose ?
Old Mar 12, 2013 | 05:13 PM
  #62
a4ls2goat's Avatar
Pulled the pumps. Both of them are working.
Old Mar 12, 2013 | 05:55 PM
  #63
That's been quite clear from the start.
Do what I said above.
Old Mar 12, 2013 | 07:47 PM
  #64
a4ls2goat's Avatar
the pumps go to 3/8th fuel line---- to the WIX filter---regulator----rails---
return from the regulator to the tank (-6)------ returns to the top of the bucket in the tank.
Old Mar 12, 2013 | 08:42 PM
  #65
OUTLAWZ RACING's Avatar
I just glance through this thread, so that being said, do you have both pumps power at one + if so both pumps need a seprate power source.Exampe>> one pump at te battery singal through a relay, pump two can go through the car harness. I had this same issue with dual walbros. They work best with seprate power sources.
Old Mar 12, 2013 | 09:10 PM
  #66
a4ls2goat's Avatar
i will do that. so your car had the same exact symptoms?
Old Mar 13, 2013 | 04:45 PM
  #67
I sure did that fix my issue. On another note walbros dont like to be deprived of voltage. Once i fixed my issue both of them went out, But i replaced them both and ran good for 3 years.
Old Mar 14, 2013 | 10:24 AM
  #68
MIGHTYMOUSE's Avatar
Originally Posted by Slow94Formula
Your problem is the pumps. They are only rated to 60 psi.
Originally Posted by MIGHTYMOUSE
yea i was wondering if the 392 had a bypass..
Old Mar 14, 2013 | 11:31 AM
  #69
Is there actually a point to the post above ?
First off, he has proven the pumps are capable of producing more than 60psi. And secondly, he isnt even using the 392 which is an external in-line pump.
But even if he was, it would still be capable of more than 60psi.
Old Mar 14, 2013 | 11:36 AM
  #70
Slow94Formula's Avatar
Then why did he write that those were the pumps he was using?
Dual walbro 392 intank.
Both running full time.
Magnafuel regulator 1:1
-6 return,3/8 feed, stock fuel rails. 80lb injectors.
Old Mar 14, 2013 | 11:40 AM
  #71
Ive no idea, but the photo clearly shows they are in-tank pumps, ie 342's. The 392 is not a dedicated in tank pump.
Old Mar 14, 2013 | 11:42 AM
  #72
Old Mar 14, 2013 | 12:39 PM
  #73
Fall Line's Avatar
Does the pressure hold when you turn off the pumps or does it bleed right down? I couldn't make the plastic straws seal to a brass hose barb, they were leaking inside the tank.
Old Mar 14, 2013 | 01:19 PM
  #74
that would be a gsL 392 not what the op claims he has (gsS).
Old Mar 14, 2013 | 02:28 PM
  #75
He does not have a 392 of any sort as can clearly be seen in the photos.
Old Mar 14, 2013 | 08:31 PM
  #76
a4ls2goat's Avatar
Sorry that was a typo.
They are 342s.
Old Mar 19, 2013 | 07:48 PM
  #77
a4ls2goat's Avatar
so i rewired the 2nd pump to a relay with its own power source.
ran the 1st pump to the factory wiring. fuel pressure is solid now!!
Old Mar 20, 2013 | 02:57 AM
  #78
How badly did you have it wired in the first place ?
Old Mar 20, 2013 | 07:49 AM
  #79
a4ls2goat's Avatar
Both of the pumps were wired together to the stock harness.
Old Mar 20, 2013 | 10:51 AM
  #80
This is what concerns me about these 340+ pumps. One alone draws nearly double the current of an OEM pump, so you can see people thinking they are a drop in solution with no thoughts to the wiring.
Just like the above, A pair of basic Walbros will be more than doubling the current normally passed through the wiring, so it's just crazy to attempt to fit a pair and not wire them appropriately.
It not only endangers pump life, but is a potential fire hazard too, by overloading wires and connectors.
At least you found the problem.
