Necking down a down pipe
Old Mar 19, 2013 | 08:02 PM
  #81
68 SS's Avatar
Old Mar 19, 2013 | 08:21 PM
  #82
MIGHTYMOUSE's Avatar
The exhaust housing I used is off the shelf pt88 so whatever that is. I recall it being fairly straight.
Old Mar 19, 2013 | 09:13 PM
  #83
69-chvl's Avatar
Looks like the pt88 has a 4" discharge, which in my mind would jive nicer with the 3.5" d-pipe vs the other fellow who noticed a big change from 5" to 3.5".
Interesting b/c both cars seem to making alot of power, so its a pretty decent comparison.
Old Mar 20, 2013 | 07:26 AM
  #84
Sales@Tick's Avatar
Will it matter much on his car, probably not. If you can fit what you can fit, fit it. There are others though Dave that will see your post and because you are MightyMouse they will think that there is no gain in going to a larger down pipe which is not true. If you can reduce back pressure why not do it?
Just fit the largest DP you can. It's that simple really.
Old Mar 20, 2013 | 08:19 AM
  #85
69-chvl's Avatar
Martin,
I'm not seeing a whole lot of value in your post(s). OF COURSE you want to try and run the biggest pipe. Of course I will fit what I can fit. All Dave has stated CLEARLY several times is that its not going to make a huge difference at my level and not to kill myself over it, and now you echoed this.
Seems to me that this site (like most others) sees "race car" and "street" car as the same in terms of needs/requirements.
Old Mar 20, 2013 | 08:26 AM
  #86
well then they need to
my opinion stands that if you get BIG gains by oversizing the downpipe (on an application like the OP) then it is a result of a REAL problem upstream such as valve springs
of course going from 3" to infinity will improve the turbo's efficiency, and likely net you a fraction of a second at the drag strip like you need Martin,
if you are at the TOP LEVEL COMPETITION you have to take advantage of everything, and are willing to hack the car to get it, however its not the topic here.
but even you start with the RIGHT SIZE turbo, and with the right CID for your goals.
for example an s475 (in my opinion) is the COMPLETE WRONG TURBO FOR A STREET 5.3
THE RIGHT SIZE TURBO IS ON THE LEFT 76 vs 475
i took 5 seconds and found this snippet https://ls1tech.com/forums/12728225-post19.html
I also made 852 to the tires with a turbonetics 76mm with a 3" exhaust flange and through an slp dual 2.5" muffler if anyone is still listening
found the vid!
keep in mind this is from like 8 years ago before i knew i had the wrong size exhaust, numbers would be lower with todays rules i guess??
It would work even better on a 5.3 than it did on my 6.0
Old Mar 20, 2013 | 09:39 AM
  #87
Sarg's Avatar
I think it depends on the set up as to which turbo to run on the street. I think one of the smaller turbine s475 with a T4 housing would be just fine. A little change of the stall and it really won't feel to much different. I necked mine down on my s480 to a 4" and plan to eventually split that to duaol 3" when funds allow and run it out the back with a cut out right before the split. I honestly do not anticipate issues. After talking with a couple of people about cam selection I think that could play a role with backpressure and tubing size as well. Everything has to work together.
Old Mar 20, 2013 | 11:23 AM
  #88
69-chvl's Avatar
I did go with a t4 1.1 ar s475 for what its worth. I had this exact turbo on a stock 6.0 with a 6spd and spool was pretty darn good with the minimal tuning that I did. Granted its going on a engine that has about 40 less cubes, but I figure a convertor should really help this turbo come alive. If this 5.3 goes, I will most certainly go with a 6.0...I just needed the 5.3 and all its accessories to get the project going.
I really thought LONG and HARD about the tc76, but the small turbine seemed to turn everybody off. Although, I'm seeing some big #'s being put up by that turbo in some cases.
Old Mar 20, 2013 | 12:11 PM
  #89
Sales@Tick's Avatar
Since I have no value in my posts I will refrain from posting in your thread 69chevl. Sorry for having an opinion.
Old Mar 20, 2013 | 12:48 PM
  #90
rotary1307cc's Avatar
So lol
How is a 5" full exhaust not a street car?
More street car than everybody dumping downpipes out the side of the car
Yes post turbine pressure is irrelevant, the expansion ratio of the housing doesnt do anything with that innocent post turbine pressure
Old Mar 20, 2013 | 02:08 PM
  #91
JAX04's Avatar
This thread delivers!
Old Mar 20, 2013 | 03:07 PM
  #92
Old Mar 20, 2013 | 08:21 PM
  #93
95bowtie's Avatar
Originally Posted by NicD
Ahh I love LS1tech, where 5" downpipes will make so much more power over a 3.5" downpipe on a stock 5.3L street car.
Amen!!
Old Mar 21, 2013 | 05:10 PM
  #94
MillsMotorvation's Avatar
Well my 5.3 with a GT 45 have 3.5 dp then down to 3inch. split to 2.5. Hope my GT91will breath. Plan to add a electronic dump like on my 87 Transnational.
Old Mar 21, 2013 | 05:45 PM
  #95
Sales@Tick's Avatar
I guess this is overkill for a S476 then.....
Old Mar 21, 2013 | 06:07 PM
  #96
Hank Peabody's Avatar
For a stock pistoned 5.3 it is overkill. We're not talking about anyones max effort forged pistoned engine, this thread was about a stock pistoned 5.3.
Old Mar 21, 2013 | 06:09 PM
  #97
69-chvl's Avatar
I have a 55 gallon drum we can cut the ends off and use it as a DP
Old Mar 21, 2013 | 06:12 PM
  #98
Sales@Tick's Avatar
It was a joke.
Old Mar 21, 2013 | 06:56 PM
  #99
LilJohn's Avatar
Since when does the pressure delta across the turbine wheel give two ***** if its a street car,race car, 700 horse or 1300 horsepower???
To the OP... necking down isnt a good thing... but it can be worked around. Ideally for your situation i would run 4 inch as far as you can, do a nice smooth conical reducer to 3.5 and fit that how you need to fit it. This method allows you to maintain as much pressure delta as possible so the wheel stays efficient. As you go back the exhaust will cool causing density to increase and airspeed to drop. The conical reducer will help accelerate the gas and hopefully prevent excessive post turbine pressure.
For every 1 psi of post turbine pressure you have, it can create 2 or 3 pre. Turbine wheels arent designed around mass flow. They work off of pressure and temperature delta. The higher these delta values, the more efficient the wheel will be.
One of the guys on the bullet posted up complaining about the numbers his full exhaust street car made.. diameter was ok... was a to the bumper system....he dropped it at the downpipe and picked up 117 rwar wheel horsepower. Its the length of run that kills you. Ill take a 3 inch 24 inch long downpipe over a 3.5 or maybe even 4 inch to the rear bumper full exhaust system any day of the week and twice on sundays.
Too much dick swinging i did blah blah 150 years ago bullshit. Theres a right way and a wrong way. The right way is whichever way makes the turbo the MOST efficient. PERIOD.
Old Mar 21, 2013 | 06:58 PM
  #100
nx88's Avatar
if you are going bigger on the engine size in the future than leave your salf some room to grow. dont cap the s476 go with the biggest dp pipe you can fit your engine will be happier= less maintenance for your street car. alot of 650+hp turbo street cars have 4in and up dp
