Engine temps...good or bad
Old Mar 14, 2013 | 07:40 AM
Sweet_SS's Avatar
I will try the 160 T-stat...had that originally. But for some reason, when I swapped out the water pump on the new motor build. The stat didn't line up on the pump. Back to a factory t-stat. I'm also ordering a turbo blanket. I did two back to back pulls yesterday and the car shot up too 214 degrees...backing back down to 205 after cruising. Sounds like the Derale's are the way to go.
Thanks again fellas for all your input.
