Lets Talk Under Hood Temps
Old Mar 14, 2013 | 01:51 PM
willizm's Avatar
Default Lets Talk Under Hood Temps
So we all know different ways to cut down temps, but what has been the most successful for you guys? I started out with a turbo blanket and swaintech coating and although its a nice coating I found it to still keep temps rather hot under the hood and my plastic wire looms where showing deformation even if they were a few inches away from the hotside. The coating also browned after a while and looked terrible. It was kinda nice to determine where the hottest exhaust gasses were building up at.
Here is how it looked going together.
I wrapped them with DEI titanium wrap and that helped out a ton. I thought it looked better wrapped anyway considering the coating turned to crap.
The combination of the wrap, blanket and coating seemed to keep under hood temps limited. I had issues with IAT and think they were more related to the small filter I had on the turbo as they would scream up during a pull. With the filter off the temps would rise but not as drastically. We built a CAI off of the compressor and dropped it down beneath the passenger headlight area in the bumper and put a much larger filter on it. Logs showed it wasn't screaming up in IAT and temps were better. Don't have a fair back to back comparison but it did seem to help and keep away from drawing up hotter under hood air.
The latest thing we did was to help channel air through the engine bay. I am not one for after market hoods and such, but since I never felt comfortable with the stock hood latch relocation we did we ultimately decided to pin/latch the hood. I didn't want to cut up a perfectly good stock ws6 hood so I bought one from VFN that looks alright. It's their WSQ hood and working with them they said I could have the optional main extractors functional that are right behind the main nostrils. By default they don't open these up.. With the position of the crossover and turbo I thought it might be ideal to have that open to draw air in and out since the vents were open right behind that area. Here is how the hood turned out.
Stock location of things
I want to hear from you guys as to what you have done to help keep temps under the hood down. Keep in mind my car is a summer daily driven car that will see the track only a couple times a year. If it were drag only I probably wouldn't have gone too extensive to keep temps down. Just trying to make the motor run happy and keep stuff from melting.
Old Mar 14, 2013 | 02:18 PM
Sweet_SS's Avatar
As you know, I mounted my rad vertical and added different pushers, but we all know it could use a little more. I'm purchasing a turbo blanket myself. Need to save up for the Derale'.s Good job on the thread. This will be most helpful for new comers....like myself. Thanks again for your help with my setup...along with a few others.
Old Mar 14, 2013 | 02:34 PM
gpr's Avatar
gpr
Your intake is very close to your exhaust. Wrapping or coating the top section of the intake likely wouldn't hurt anything to keep intake temps down.
Old Mar 14, 2013 | 03:59 PM
06cobaltSS's Avatar
basically evertthing you did.
Old Mar 14, 2013 | 06:28 PM
rotary1307cc's Avatar
Holy crap how big are the OPs up pipes?
Old Mar 14, 2013 | 07:52 PM
Blown02Camaro's Avatar
Does any body know if they make a vented hood for a camaro?
Old Mar 14, 2013 | 09:19 PM
pwrtrip75's Avatar
Just remove the weatherstrip on the cowl. I did that and it created a nice gap for air flow. I also added a turbo blanket and it helped a lot.
Old Mar 15, 2013 | 02:15 PM
willizm's Avatar
I could see how that would help. Wonder how many people do that.
Old Mar 15, 2013 | 02:19 PM
Chocolate Apocalypse's Avatar
I used to have a Mecham single extractor hood on my 2000 Camaro. They also make one with more but it looks a tad ricey if ya ask me
Old Mar 18, 2013 | 01:59 PM
RedRocketZ28's Avatar
I did and it helped quite a bit.
Old Mar 20, 2013 | 08:28 AM
Brian396's Avatar
Cheap easy and works.
Old Mar 20, 2013 | 09:40 AM
Reject's Avatar
run it without a hood? RoadKill style
I honestly never noticed any soaring tempuratures under the hood on mine and mine had everything in stock location including AC stuff.
Old Mar 20, 2013 | 10:37 AM
TurboJoe@Straightline's Avatar
Nice ill thread bud! BTW your car sounded mean on the dyno! Sorry I missed it but seen the vids.
To the guy asking about his crossover size its 3in....and as to te hocus pocus everyone talks about with tube size...the car blows that theory out the window lol
Old Mar 20, 2013 | 11:04 AM
willizm's Avatar
Thanks buddy I asked Nick to send me a copy of the dyno sheet since I lost mine. Will post up results here
