windowed block ??
Old Mar 16, 2013 | 09:56 PM
LSOHOLIC's Avatar
Default windowed block ??
Looking for some info on sbe failure points. I have no problem pushing a sbe 5.3/5.7/6.0..etc to it breaking point, I just dont want to put oil under the tires !!
So all you guys who have hurt/broke a sbe motor, what and where were the failures points ?? Has anyone windowed the block, pan or had oil containment problems ??
140mph+ at the track with a sbe have any of you considered a diaper ??
Thanks............
Old Mar 16, 2013 | 10:03 PM
godlyxdan's Avatar
Most common failure point I've ever seen around here is breaking ring lands out of stock pistons. A couple rod snaps here and there but for the most part in boosted applications the piston lets go first
Old Mar 16, 2013 | 10:12 PM
LSOHOLIC's Avatar
Yeah, the one I've seen are popped piston tops and broken ringlands. It would suck to put your 30K car in the wall because of a $500 dollar engine.
I know anything can and will happen but I just wanted to see what the majority consensus is/was.
