Copper Head Gasket Spray ?s
Old Mar 20, 2013 | 09:32 AM
Reject's Avatar
same here, only the outer layers. I may try all of them inbetween. wonder how much more thicker it will make the gasket and if so, effect the compression? .0001:1
Old Mar 20, 2013 | 12:53 PM
Burken01's Avatar
Yeah I dont see it making a big diff in CR or quench... very minimal
Old Feb 17, 2014 | 08:15 AM
96TTtrqmnstr's Avatar
For you guys that use the copper spray on your HG's .... Do you let the spray dry (overnight?) before installing or just wait a few minutes after spraying and install them "tacky"?
Thanks guys!
Old Feb 17, 2014 | 08:30 AM
Camaro9969's Avatar
Thanks guys!
Just before installing wait a couple mins till tacky just like you said
Old Feb 17, 2014 | 08:34 AM
elkydragger's Avatar
I did mine tacky. My engine is completely filled so I don't have to seal water only combustion. Tacky lets it fill into any imperfections in the deck surfaces.
Old Feb 17, 2014 | 02:16 PM
93camaro_zzz's Avatar
Interesting read:
http://www.lsxtv.com/features/pri-co...y-mls-gaskets/
But, imo it doesn't matter either way. But I sure do get tired of seeing: "Well my friend has a 4000hp drag car and he sprayed his gaskets, so that means that obviously everyone should do it, or else they will blowz up!"
lol
