Turbo fox gearing
Thanks
http://www.f-body.org/gears/
just select 1998 M6 and fill in tire size and gear
Thanks
i use 6krpm as a reference because thats where i shift with a stock bottom end. with your motor being forged, youll obviously spin higher which means youll get more mph out of each gear. With 650whp in a foxbody, youll be over 140mph in the 1/4 mi and you dont want to be shifting into 5th gear. 3.31s are perfect.
Thanks
Although the current 3.31 would still work well, especially as the vehicle is quite light
