Where to mount proflow bypass valve?
Old Mar 25, 2013 | 01:02 PM
sweet99ss's Avatar
Default Where to mount proflow bypass valve?
Can I mount it anywhere in the piping or is there spots better than others? I have the cx racing intercooler kit if that helps?
Old Mar 25, 2013 | 01:49 PM
conan's Avatar
I have always been told to mount it before the intercooler if possible. The idea is to keep the intercooler temps down during part throttle by not sending the air through the cooler and then bypassing it to the atmosphere. I did this on my twin cooler kit and I'm going to mount it before the front mount cooler here in a week or 2 when I get the motor back in my car.
Old Mar 25, 2013 | 02:14 PM
sweet99ss's Avatar
Okay that what I thought. How about welding it. Is the proflow bypass valve aluminum? I know all my intercooler stuff is aluminum.
Old Mar 25, 2013 | 03:09 PM
conan's Avatar
Whats the Proflow unit look like ? This is what you use to mount the big red bypass...
Old Mar 25, 2013 | 04:46 PM
sweet99ss's Avatar
It has a piece that comes off the bottom that is attached to it unlike the big red. If it's aluminum can I just get it welded directly in the pipe? Here is a pic
Old Mar 25, 2013 | 04:49 PM
sweet99ss's Avatar
Okay went out to the garage and looked at it. It is aluminum.
Old Mar 25, 2013 | 11:25 PM
conan's Avatar
I would weld a pipe to the charge pipe that's the same size as the bottom of that valve and use a straight silicone coupler to attach. I would want to remove it if i had too.
If you do end up welding it to the charge pipe I would at least disassemble the valve to weld. Aluminum soaks up heat fast when welding.
Old Mar 26, 2013 | 12:29 AM
Detoxx03's Avatar
My pro flo was on the pipe coming off the blower at the bottom before the intercooler and when I replaced it with a Tial Q it was welded in the same position.
