Procharger idler pulley shot?
Old Mar 28, 2013 | 06:02 PM
SSInnovations's Avatar
Default Procharger idler pulley shot?
Is this thing toast? It turns fine but has resistance, should they spin freely?
Attached Thumbnails Procharger idler pulley shot?-100_3046.jpg   Procharger idler pulley shot?-100_3047.jpg
Old Mar 28, 2013 | 07:33 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
There should be some resistance since it has grease filled bearings, but there's a difference between resistance, and trashed.
Old Mar 28, 2013 | 07:43 PM
It is perfectly smooth when rotating but will not spin freely. I am just worried because it's obviously had a lot of heat in it. New to Prochargers.
Is there a replacement option other than the $85 procharger one?
Old Mar 29, 2013 | 04:30 AM
stevieturbo's Avatar
Depends on the bearings really. If they spin smoothly with no roughness, and the seals are intact with no leakage present then they are probably fine.
And I'd imagine the bearings are relatively easy to replace.
Old Mar 29, 2013 | 07:00 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
You can take the bearings out and go to your local Napa and find replacement bearings. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Mar 29, 2013 | 07:09 AM
UNDER PRESSURE MOD
If it's perfectly smooth, but won't spin freely, then the bearings are doing their job. I say leave it be. As long as there is no slop or free-play in the pulley, then put it back on. If you were able to spin it and it spun freely, then the bearings would be shot.
Old Mar 29, 2013 | 08:49 AM
Slowhawk's Avatar
LS1Tech Sponsor
I'd replace it just because of the wear on it. That will help chew belts.
Old Mar 29, 2013 | 10:59 AM
Is this kind of wear common? Was is caused by belt slip?
