How to prevent meth spraying on 2-step?
Old Apr 1, 2013 | 03:33 PM
dville_gt's Avatar
i spray meth on the 2 step (using hobbs @ 10psi for activation), never had any issue at all this way.
Old Apr 1, 2013 | 04:26 PM
35thsscamaro02's Avatar
Huh well I guess I'll try it with meth before I wire it with a meth cut off
Old Apr 1, 2013 | 05:30 PM
Sales@Tick's Avatar
I think you will have to do a lot of tuning just to get the AFR where it needs to be while it's spraying for max performance. For most people on this website I think it doesn't really matter because cutting 1.2x and 1.1x 60' are only things that crazies like me are actually shooting for attaining, but I still think for maximum performance that keeping it off while on the trans brake is best.
Old Apr 1, 2013 | 06:15 PM
dville_gt's Avatar
I've managed a bunch of 1.30's with the meth spraying on the 2 step. You really think it slows you down?
Old Apr 1, 2013 | 06:21 PM
Sales@Tick's Avatar
James,
I don't know for sure. I use to do it on my old turbo car and my AFR with my two step turned off was in the high 10's spraying meth on the trans brake. I can only imagine that with a leaner AFR it would come out of the hole harder and then progressively richen the AFR up as boost comes in and wheel speed goes up once the car is moving.
I would think that being able to progressively bring fuel in instead of having to take fuel out or do other things to compensate for the methanol spraying would be easier and faster along with being more responsive.
I'm going to try it both ways when my car is up and running with the turbo set-up if I ever remember to try it out both ways.
Old Apr 2, 2013 | 11:13 AM
dville_gt's Avatar
James,
i see what you are saying. maybe that's why i like to leave with ~20psi, gotta overcome that issue!
Old Apr 2, 2013 | 03:05 PM
Slowhawk's Avatar
LS1Tech Sponsor
The meth spraying on the 2 step in my car helps it spool a good bit.
Old Apr 2, 2013 | 04:07 PM
I got my 2-step today and wired it without a meth cut off. Sounds sick but car stumbles when I let off the gas. I haven't tried staying in it yet. Seems I should just wire a cut off for the meth since it has no benefit being sprayed on the two step for me.
Old Apr 2, 2013 | 05:55 PM
3pedals's Avatar
the turbo still makes heat while your on the 2 step, spraying meth while on the limiter definately has merrit, but if the car loads up as Martin suggest, then you need to pick your poison
Old Apr 2, 2013 | 06:17 PM
True for turbo guys. I'm running procharger though.
Old Apr 2, 2013 | 06:37 PM
3pedals's Avatar
doesnt matter, if the procharger is making boost at the 2 step rpm, its making heat in the intake tract
Old Apr 2, 2013 | 06:56 PM
  #32
Good point.
Old Apr 3, 2013 | 10:22 PM
  #33
MillsMotorvation's Avatar
Had this problem, but I just turn up the boost that the meth come on so I can build more boost with out it spraying. Had mine coming on at 4psi but car would flood if I try to leave with 5psi, so I set the meth to come on a 9psi, and I can leave with boost to that number.
Old Apr 3, 2013 | 10:31 PM
  #34
CamaroZ28_LS1's Avatar
My car sprays meth when I'm on the 2 step, but not as much as it does WOT. It doesn't seem to hurt it at all, as long as your moving air with the meth spraying.
Old Apr 16, 2013 | 09:29 PM
  #35
Troy's Avatar
Originally Posted by Slowhawk
If it's an alky control setup it has a wire to hook up to stop spraying on the 2-step.
I'm glad you did the ALky kit for me then. Where does that wire come off of the Alky kit?
With a manual car, I didn't think the 2 step would help me build boost at the line.
Old Apr 16, 2013 | 09:48 PM
  #36
3pedals's Avatar
The 2 step , and a timing retard while on the 2step will build all the boost you could want on the line
Old Apr 17, 2013 | 09:28 AM
  #37
Troy's Avatar
On a 6 speed with a procharger? I guess I'm really behind here with my setup
Old Apr 17, 2013 | 01:40 PM
  #38
3pedals's Avatar
Lol, thaught you had a turbo stickshift . You obviously have no trouble building boost at the line with a supercharger.
Old Apr 17, 2013 | 09:09 PM
  #39
Troy's Avatar
Hey- Thanks for your reply about the boost with a 2 step and a 6 speed running a procharger. I don't want to sound stupid here but I thought the car needed a load to build boost? WHen I build RPM to get ready to launch (I haven't bought a 2 step yet), the boost gauge shows that I go from vacuum state to maybe 1 lb of boost (if I remember correctly). Now, that is without a 2 step but I would think the 2 step makes no difference as I'm holding the RPM with the accelerator and the 2 step is doing it by cutting spark...I've been searching posts but haven't seen where I see people building boost on 6 speed procharger with a 2 step, only on turbos. Did I miss something
Old Apr 18, 2013 | 08:17 AM
  #40
It will build boost. Works great and makes launching the car much easier
