High HP(1500hp+) EFI/E85 Fuel Sytems, what are you guys using? Pics welcome
#41
TH400? What rear gear?
#42
We can offer dual staged pumps for our ProTouring setup. http://www.nastyperformance.com/shop...ing-fuel-tank/
Or give me a call I will help you spec the setup for your needs.
#43
I would love to run one of your set-ups and honestly have been drooling and feigning over one for a long time, but I don't think I can afford you and I mean that with all respect! LOL!
Sponsor a poor 25 year old?
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
#47
Gingervitis Addict ![](http://s24.postimg.org/5ong4sl1t/Gingervitis2.jpg)
Thats how some of the new EFI boats (that have LSx engines) work. Its called a surge tank. The low pressure fuel pump fills up the surge tank, and the return is an open fitting at the top of the tank (tank is sealed to the fuel system). The high pressure pump takes fuel from the surge tank, and returns to the surge tank.
#54
An external swirl tank is standard practice for track cars. It will basically let you race around a circuit running the main tank to almost empty with no fuel supply issues.
Obviously the more power you make, the larger the swirl may need to be, depending of course on the abilities of the lift pump to keep it full.
