CxRacing 80mm or S475?????
piston and rod 5.3 9.5cr
317 heads
Pro flow intake
LIL JOHN CAM (still need)
th400 trans
9" with 3.00 gear
what will make more juice?....... cxracing T4 80mm or the s475 T6 1.32 96mm. Im thinking the 475 but idk much about the cxracing 80mm either. Just basing it off of the ebay specs on the 80 it looks like it will choke on the turbine before the comp dies. I know Denmah is running the 80mm...so any word on the two would be great...thanks
Yea ill def call you when the time comes....The last cam I got from you worked good....
