DIY ceramic coating
Old Jan 24, 2017 | 05:35 AM
  #61
a05c's Avatar
Originally Posted by ls1charged
so i just got some of this stuff in the mail, ill be doing my hotside when it gets here, sounds like ill be doing it outside from what your guys are saying, can this be brushed on or does it have to be sprayed on? probably better coverage being sprayed on im guessing, i dont care how it turns out honeslty cause im gonna wrap it too
Whatever you do, prep work is key. Sandblasting and cleaning extremely thoroughly. I masked off the V-band clamps when I did ours, just to keep from causing any interference problems.
Probably better off spraying it, I've never painted it on but I think it'd look better with it sprayed on and probably get better coverage.
Old Jan 24, 2017 | 10:31 AM
  #62
Five O's Avatar
It need to be sprayed on. I forget the exact thinness but it's thin. Too thick and it'll come off they said
Old Jan 24, 2017 | 10:34 AM
  #63
ls1charged's Avatar
yea i did some searching and it seems it needs to be applied in light coats, ill post up pics when i get mine done next month
Old Jan 24, 2017 | 10:53 AM
  #64
pdxmotorhead's Avatar
HAs anybody tried the POR Exhaust paint version? I've used some of their other products and am pretty happy.
Old Apr 18, 2017 | 02:08 PM
  #65
LS198Z28's Avatar
Update: I've ran it for nearly 2 years on the street in all sorts of weather too. Still looks like new. You guys are right about spraying it too. It's rougher than anything I've ever smelled.
Have you noticed that it lowered the under hood temp? I'm considering buying some to to coat my hotside.
