Help Needed! power leveling off >:D
Old Apr 14, 2013 | 03:48 PM
underpressureWs6's Avatar
Default Help Needed! power leveling off >:D
Powers leveling off starting at 4300 rpms and can't figure out why, I attached a dyno graph so you can see what I'm talking about, car is a 00 trans am ws6 LS2 block 365ci, PRC stage 2.5 LS6 heads, LS6 intake manifold, ECS big blower cam, R&R steel billet rods, stock crank, manley forged pistons 10:1 compression, D1sc 14# of boost, twin 4.5 intercoolers, methanol injection 60/40 mix with water, lvl 7 4l65 trans, yank py 3400 converter, moser 9 inch, 3.50 gears. Let me know if you guys need more info, thanks for the help
Old Apr 14, 2013 | 03:52 PM
I'm on my cellphone and trying to upload the picture of my dynograph but its not letting me so any help would be appreciated lol
Old Apr 14, 2013 | 03:57 PM
Anyway peak torque is 641 at 4300 rpm and power peaks out at 527 at 4300 rpm and stays at this power level all the way through 6500 instead of climbing like it should
Old Apr 14, 2013 | 04:00 PM
chiaj144's Avatar
What is the boost doing? What kind of dyno? My turbo setup would actually drop power after 5k or so but it was dropping boost as well. The dyno couldn't load the car enough. I would make 14lbs or so at 5k and be down to 10 or so at 6500. On the street it makes the 14 to 6500. How does it feel on the street. Does it pull to redline or does it lay over?
Old Apr 14, 2013 | 04:04 PM
The boost stays at 14 at 6500rpms but on the street it keeps pulling hard it doesn't flatten out at all
Old Apr 14, 2013 | 04:07 PM
3.8redbird's Avatar
What springs?
Old Apr 14, 2013 | 04:09 PM
3.8redbird's Avatar
What kind of dyno?
I know my local one used to suck at loading turbo and centri cars due to a crap brake.
On a dynapak and a mustang dyno its done this except on the dyna pak it read a bit higher 648rwtq at 4300rpm and 644rwhp at 5400rpms and stayed there untill 6500 rpm instead of climbing
Old Apr 14, 2013 | 04:11 PM
Prc dual valvesprings
Old Apr 14, 2013 | 04:49 PM
ablakez28's Avatar
I had this happen when I accidentally installed the wrong MAP sensor table. Still made 790rwhp haha but car fell off around the same spot. Fixed it and made 975rwhp
Old Apr 14, 2013 | 04:58 PM
Wow that never occurred to me, ill talk to my tuner and see what hethinks aabout that
Old Apr 14, 2013 | 07:25 PM
Old Geezer's Avatar
Data logs??????
