1985 6.0 turbo truck
Old 04-17-2013, 09:12 PM
shaved87's Avatar
]forgot to add ^^^^^^ that i have an ams-500 controller. Here is a pic of the motor when it was first rebuilt. I have only put maybe fifty miles on that setup since then. I felt like i was "cheating" myself with the power1985 6.0 turbo truck-motor-first-build.jpg
Old 04-17-2013, 09:17 PM
LS5.3stang's Avatar
is it lq4 or lq9 ? they have differant rods ,lq4 rods good to 800hp, lq9 900 u will be pushing it to make a thousand . it may grenade , imho
Old 04-17-2013, 09:21 PM
shaved87's Avatar
i beams?? everyone been suggesting hbeams they say theyre stronger and will hold the 1k intended
Old 04-17-2013, 09:23 PM
shaved87's Avatar
its a lq9 but im changing the rods and pistons no matter what because the compression is too high for the turbo and the im pretty sure those pistons will be getting pretty hot with nitrous as well
Old 04-17-2013, 09:49 PM
BMF_Racing's Avatar
Take a look at the ratings on hbeam and ibeam. All that I've looked at, ibeams were rated higher and cost more too. My Callies ibeams are rated 1500hp where their hbeams are 800hp iirc (cost much less also). At 1000hp I think you will be fine either way, I have a dendency to go overkill.
As far as the n20, I would set it up on a Hobbs switch to say 6 psi to turn the n2o off and the turbo will take over from there. There really shouldn't be a need for it after the turbo is spooled, if there is then the turbo is too small.
Hope that helps.
Old 04-18-2013, 04:44 AM
Sarg's Avatar
Honestly I would skip the nitrous personally and focus on the turbo set up. I do not believe you will have any issues at all spooling that turbo with the cubes you have. Just stall and cam it appropriately. What fuel do you plan on? Maybe I missed it.
Old 04-18-2013, 06:35 AM
BMF_Racing's Avatar
X2 I agree.
Old 04-18-2013, 09:56 AM
shaved87's Avatar
Would the 1.32 a/r be a problem ?? Would a smaller one help .? More pics coming later this week getting the coldside fabbed up
Old 04-18-2013, 10:12 AM
Sarg's Avatar
Again with the appropriate cam and stall converter I think you should be at full boost in the 3500- 4000 rpm range if not sooner.
Old 04-19-2013, 11:35 AM
shaved87's Avatar
Crossover done big azz 5" downpipe on the way! What has everyone been doing for mufflers?? Or are they needed
Old 05-04-2013, 05:43 PM
shaved87's Avatar
Default 5" downpipe done
ok ive got the down pipe down past the firewall. I couldnt fit 5" the entire way so i had to use a 5 to 4" adapter to fit past the firewall1985 6.0 turbo truck-downpipe-done.jpg
Old 05-04-2013, 05:45 PM
  #32
shaved87's Avatar
a/w intercooler also i think im gonna try to shove it behind the dash and run the water lines under the middle console and out the back of the truck to the 5 gallon ice box 1985 6.0 turbo truck-intercooler.jpg
Old 05-04-2013, 05:55 PM
  #33
shaved87's Avatar
i have a few questions about plumbing for the vacuum lines. I bought one of the vacuum manifolds that ill probably mount somewhere on the firewall, I have two ports on the wastegate (one on top and one on side) one port on the procharger big red bov, boost gauge, and boost reference on the FPR. How and where do i plump these lines. Ive read a few posting where they say reference the Wg off the Turbo housing but Im looking for other options also where does this hose go off the bov?? boostcontroller etc????
Old 05-04-2013, 05:56 PM
  #34
shaved87's Avatar
1985 6.0 turbo truck-aluminum-piping-table.jpgcoldside piping on the way
Old 05-20-2013, 09:33 PM
  #35
shaved87's Avatar
Default Cold Done
Cold side and intercooler mounted under the dash ……next plan is to get the pro charger big red bob mounted before the intercooler and the IAT sensor right before the throttle body
Old 05-20-2013, 09:39 PM
  #36
shaved87's Avatar
Default next ??
do you guys think that the billet wheel over at forced inductions will be good as far as power increase?? what about the 1.58 a/r housing ??
Old 05-20-2013, 10:09 PM
  #37
shaved87's Avatar
Old 05-20-2013, 10:10 PM
  #38
shaved87's Avatar
Quick Reply: 1985 6.0 turbo truck
