Anyone run 18psi on 93 octane stock shortblock?
Just think of it this way. The ECU only knows about fuel that IT is commanding to go into the cylinders. Meth is its own system that is separate from the ECU and is in fact a fuel. So the ECU does not take it into account because it does not know it is there (unless you were spraying it in closed loop for some reason, lol) and has no way of knowing how much or little you are spraying.
