***LMR 2013 GT500 makes 1106rwhp!!!***
Any ideas what the power would have been on 93 octane pump? do you think it would have made over 1000rwhp?
Closed ex-Sponsor Account
We didnt have the spark lead hooked up due to having to remove the cover of the valve cover that holds down the coil on plug setup. we didnt want them to be able to come lose during the pull. No spark lead = no torque number. The car makes 25psi of boost by 2800rpm. Use your imagination for the torque graph.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
no doubt, I wanted to know if the blower is maxed out because the other member that has a 4.0 seems to have maxed it out at about 1000rwhp too but made much more torque. The 4.0 is rated at 2500CFM and im wondering why no one is making 1000+ from it?
FYI 2500CFM is what an F2 Procharger flows, not sure if the Whipple's flow is over-rated?
