Sloppy mechanics how to: broken exhaust manifold bolt removal *update 8/1/16
Someone sticky this! I just had 2 break off for no reason(literally no reason. I didn't even touch the bolts. I heard something fall on the floor and there was a bolt head!). 30 secs later and both were out! Thanks so much for posting this!
how is the head fucked? you have to be careful not to overheat it when you are welding but I did this to 6 studs on one head once back in high school, shop teacher taught that trick to me, worked great.
if its not broken to far into the hole, you can center a nut over the hole
and plug weld it-the nut has to be smaller (center) than the bolt
I was given a free 6.0 because rather than try and rem. 3 broken studs they replaced he engine-I only wanted the block anyways, lol
#37
No I'm serious. Guess I may of gotten it too hot, the flange area around the hole broke away. It's like a crater around the hole now. Oh well, looks like ill have one 862 head, and one 706. Sloppy.
