Boost and steam vents, 799 heads what to do
so the water flows through the whole block and heads, cept for this area above the rear cyls that will make them explode, and the only way for them to not explode is to put a pinhole sized coolant passage in the top corner of the head by the intake, not even the cyl...
sounds like bullshit to me
Plug em off and go to the next thing . With a turbo car those steam vents will be the least of your problems. While your worried about those steam vents im out doing burnouts in both of my turbo cars that have them blocked.
figured id ask, in all your turbo LS builds how many have you blown up?
out of all the other cars, i cracked a piston in the ventura years ago getting greedy with timing, and my friends mustang kicked a rod when his 6.0 ran out of fuel pump.
other than that, i think i broke a piston once a month or more in my fairmont.
we have built and tuned many other cars that have not broken the motors, my friends notch went thru a few transmissions and converters till we found stuff that could take out the power these can dish out.
