745-rwhp/729-rwtq '13 CTS-V Sedan | VR Heads+Cam/Pulleys/Nitrous!
Where do you even start with a build this cool. Four doors of Cadillac luxury, Weld RT-S S71 wheels over custom powder coated 6-piston Brembo calipers, and 745-RWHP on tap at the push of a button. This is one NASTY 2013 Cadillac CTS-V Sedan sporting our exclusive VR750HP LSA Performance Package along with an additional nitrous upgrade and all of the supporting modifications you would expect on a build of this caliber.
Engine:
WCCH Stage II CNC-Ported LSA Cylinder Heads
Vengeance Racing Custom Camshaft Plus Kit
Custom VR LSA supercharger cam
VR .660-inch lift Dual Springs with Ti Retainers
VR 5/16-inch Hardened Pushrods
Comp Cams Trunion Upgrade
Katech C5R Timing Chain
Melling Oil Pump
LS7 Timing Gear
LS2 Dogbone Timing Damper
Supercharger:
VR Ported Blower Snout
VR Ported Supercharger assembly
D3 Cadillac Supercharger Lid
102mm Nick Williams Throttle Body
ATI/Lingenfelter 2.55-inch Upper and 9.17-inch Lower Pulleys
Idler Relocation Bracket
Solid Isolator
Cooling:
Vengeance Racing Heat Exhchanger System
High Capacity Pump
Snow Performance Stage II Methanol Injection
Nitrous:
Nitrous Outlet 102mm Plate System
CTS-V Specific Switch Panel
Remote Bottle Opener
Stage II Accessory Kit
NOS Progressive Controller
Supporting Modifications:
American Racing PROTOTYPE 2-inch long-tube headers
American Racing 3-inch X-pipe
160-degree Thermostat
FIC 80-lb/hr Fuel Injectors
Tuned by Vengeance Racing
Suspension:
D3 Cadillac Lowering Springs
Weld Racing RT-S S71 Wheels with M/T Drag Radials (on the rear)
Custom Powder Coating:
6-piston Calipers with VR Logo
Supercharger Lid
Strut Tower Bar with CNC Engraving
Results:
We'll just let the graphs speak for themselves...
683-RWHP and 659 LB-FT OF TORQUE ON MOTOR
745-RWHP and 729 LB-FT OF TORQUE ON SPRAY!
Video:
Check out this bad Cadillac on the dyno, "test track", and parking lot:
We would love to hear your thoughts on this build and, as always, we're more than happy to answer any questions you may have. Hit us up below, on our , or through our http://vengeanceracing.net. Thanks!
Engine:
Melling Oil Pump
LS7 Timing Gear
Supercharger:
Solid Isolator
Cooling:
High Capacity Pump
Nitrous:
Suspension:
Supercharger Lid
Results:
Video:
Facebook Post
awesome , do you do anything with that vr 750 kit for the trans or rear end ? How is that stuff holding up .
Sick build . Love the rims and brakes and all the texture matching powder under the hood .
