BOV Operation?
With the heavy spring it will only open a smidgen at full vacuum (~23 inHg), but not even enough to let out any air. But when I close the throttle at more than about 2-3 psi of boost the BOV will open. The turbo will also start fluttering before the BOV opens, and it's a noticeable gap between these two events, probably up to 1/2 second. Once the BOV opens the fluttering stops. If I close the throttle at less than 2-3 psi the BOV stays shut and the turbo just flutters.
Is this okay, or should I trim the BOV spring down so it opens sooner? I pulled it apart and inspected it, seems fine mechanically.
Build boost and let out of it, it opens up to release the pressure then closes back up. This way the turbine does have to work so hard to spool back up. I found info on it from a few different websites
Build boost and let out of it, it opens up to release the pressure then closes back up. Under boost or when manifold vacuum drops...spring pressure closes the valve.This way the turbine does have to work so hard to spool back up. I found info on it from a few different websites
You may wanna re-read the info, or check your sources for accuracy
Yes... Wide open at idle. You should have manifold vacuum to the BOV.
You don't want or need boost at idle.. And yes it will pull air in before throttle plate.
The purpose of the BOV is to limit the amount of surge back to the compressor when boost is built and the throttle is closed. Understand?
I just like the OP want to make sure everything is working correctly
Ive had to use washers to shim a bov before, its crude but works well.
ran into the exact same issue when I fired the car ive been building. car idles around 14" of vacuum. Heavy spring wouldnt let it open (opened around 25" on a vacuum pump) light spring was wide open at idle (opened around 11" on a vacuum pump) and wouldnt shut on a free rev
tried shimming the light spring which got it shut but ran into a coil bind issue and wouldnt let it open all the way. Called RPS (guys are awesome btw) and they recommended either purchasing a TIAL spring or the less expensive option of cutting down the heavy spring.
Started cutting down the heavy spring and reshaping the end curve to sit correctly. Started with 2 coils from the end tip and then went a half coil at a time. Ended up with 4 total coils and its perfect now. Just comes off the seat at idle but still shut, shuts on a free rev, opens with the throttle is closed, back to close at idle. Again this is a car idling at 14"
FWIW
FWIW
^^ That should let you keep the light spring but keep it closed at idle.
